Baofeng UV82C display channel vs freq
Hello,
Does anyone know how to change the display to show the channels and not just the frequency?
I have done:
-hold menu and turn on
-changed MDF A and B to name.
Any other suggestions? Could it be that my names are too long? (would it not simply truncate?)
Thanks,
~Susan
Severn, Maryland, USA
#2
Hello,
I have done:
Thanks,
~Susan
Firstly, welcome to the Radio Reference forums, Susan. Secondly, as for your display question, once you changed MDF-A and MDF-B to NAME, did you then press MENU again to confirm the selection before pressing EXIT? If you did that and it's not displaying the alphanumeric name for the channel position, then I'm not sure what is amiss.
Let me know if you are still having trouble. And again, welcome to the Radio Reference forums.
73, Dave K4EET
PA
#3
Also, check out the Budget and Entry-Level forum which is specifically geared to questions about Baofeng and similar radios.
