Bartholomew County Highway
indiana1983
Columbus Indiana
Does anyone know which frequecy is that recieve. I dont know which one is ther recieve to program on my scanner.
159.075
151.085
there call sign is KJH290
K9JGB
Johnson County, Indiana
Barth Co HWY
000151.08500000 1 1 1 FB2 1 75.000
000151.08500000 2 1 1 MO 40 75.000
000159.07500000 2 1 2 MO 40 75.000
FB2 is your repeater output.
MO is your mobiles transmiting into the repeater.
Always look at the number of units, and usually you can figure it out. 40 mobiles and 1 fixed base 2 (repeater)
Again use the search functions on every website and usually you can answer your own questions.
You can search station class under search and find out anything you want to know about the codes.
