I have probably a dumb question for the antenna experts out there as it relates to base antenna height above ground level.
I live an a mountainous area where elevation changes quickly over short distances. My house is at roughly 1,000 ft. ASL and down the street from me it gets down to about 800ft. ASL or so and even lower.
Theoretically, if my antenna is mounted only 10ft. above the ground (obviously not ideal), and someone down the street from me has the exact same equipment but with the antenna mounted on a 50 ft tower, who would get the better range? Again, considering exact same radio, antenna, coax, etc.
Would I get the better range because my antenna is still at a higher elevation? Or would the person down the street get better range because their antenna is mounted at a more ideal height above ground level?
This is mostly just for my own curiosity.
Thanks!
Thanks!
