I've got a Sirio 17 foot base antenna mounted to my deck. It's almost perfect SWRs (under 1.1). Question is, all my radios seem to get a constant 7 pounds worth of background noise, is that normal? I've also been doing tests where I transmit from my mobile back to the base and I'm not so pleased with the range (fades out around 3 miles, no hills or anything). I've talked to a neighbor pretty clearly at almost double the range.
Its not grounded, could that be the answer or something else?
