This is for a dual band non Amateur (2m/440m) base station antenna.
I have a Diamond X50NA base station antenna, but there is a problem with the female N connector. I don't see a way to remove/replace the fitting. Visually it appears ok, but even after changing fittings on the feedline (N) contact is not good. RLB scans vary and it wasn't acceptable to me. I have to assume the center receptacle is not forward enough (ruling out the name N connectors). Also the frequency shift from 2/440m is very slight at VHF making it less then useful.
Anyway, I'm looking for a replacement and this combo seem to be the best choice (that I have found so far);
Nagoya NMO-200C – BaoFeng Radios
Nagoya GPK-01 – BaoFeng Radios
I did find this review;
Review NMO-200A/C - Miklor
My question was, what I don't like is the (what I call) outdated use of a SO239 instead of a 'N' connector. I realize at VHF, it's not a big deal, UHF is another matter. I look around for other choices and I only found the Tram, a 4 element wimpy design (to say the least). The review did mention the ground plane being important.
Between the mini Tram and the Nagoya, input of both?
