kixntuff
Hello fellas,
I'm really interested in how bandwidth works. I've been reading a lot about it and some goes over me head and some just raises more questions. A brief description of what I'm getting ready to get into. I'm going to be racing the BAJA 1000 on the Baja Peninsula in November and we'll be using radios for coms. All Pit teams, rescue, Score, etc etc will be operating in the business band ranging from151.625Mhz up to 155.???Mhz. The main facilitator will be operating on 151.625Mhz. Race teams choose their frequencies in between those said frequencies mentioned above. It is also instructed by the main facilitator not to choose a frequency in between bands so you don't get bleed over. and that he will not relay to you if you choose a frequency in between bands. I understand what bleed over is and that if you're operating on 151.625Mhz with a band width of 12.5Khz that you can't choose a frequency of 151.634Mhz. I think I'm getting all tripped up because I saw someone's program sheet for a good bunch of the frequencies assigned for a previous race and the facilitator was operating on 151.625Mhz 5Khz bandwidth, others and a good majority where operating at 12.5Khz bandwidth and a couple other at like 25Khz bandwidth. If I could I'd like to use a frequency running around 25Mhz bandwidth for simplex coms between my teams chase vehicles. So this brings me to my 1st question and sorry if these seam silly, but I'm still studying for my amateur license and trying to learn at the same time I'm trying to get coms set up for my team. Also, I understand all the rules and the does and don'ts so lets try and keep it on topic. It's a free for all down in ol Mexico during the time of this race and Score-International has special permissions from the Mexican government for coms during race time.
Is there already a bandwidth assigned to business band 150Mhz to 174Mhz I believe it is. What is that bandwidth?
2nd question, once I know the bandwidth, I should use the step feature in my radio and assign it to the appropriate bandwidth correct? That way when tuning, it will only jump through and scan correct frequencies and not in between bands right?
3rd Sounds like I should also set the radio for wide band instead of narrow band correct? Does it really affect signal strength if one where just to leave there radio set on narrow band?
4th Would choosing a frequency closer to 155Mhz carry better than say closer to 151Mhz?
5th When operating simplex on a particular frequency, can you change your bandwidth on that said frequency? For example, 151.625Mhz, can you change settings in your radio to operate on it sometimes at 5Khz bandwidth and other times at 12.5Khz? I think the only menu settings I've ever seen in a radio allow you to change the step and from wideband to narrowband, not the band frequency. This particular question is where all the confusion is basically and in how bandwidth really works.
Thanks,
Kix
Thanks,
Kix
