Baton Rouge PD
brscanning
Baton Rouge, LA
Anyone able to hear the Baton Rouge PD? I am not picking them up on the LWIN system. I have tried several different scanners. Other ID's are working fine on the Baton Rouge area repeaters.
charlie12
Pride, LA
I 'm in Pride and I just heard them on the Baywood tower at about 0226 hrs.
Too bad the State doesn't know that the Baywood tower is in Pride and not Baywood. :)
brscanning
Baton Rouge, LA
Thanks. After doing some searching I found that they are showing up on sites that I would not normally expect (Geismar and Iberville). I need to do some more work on this.
brscanning
Baton Rouge, LA
Update
After some logging overnight, I found that the BRPD was on the following sites (at least from my location):
Site - Hits
Baywood - 7
BR Simcast - 42
Geismar - 350
Greensburg - 476
Iberville - 220
Jackson - 117
Livingston - 375
Ramah - 287
