Battery or charging circuit.
My battery is not wanting to start the car since it's gotten cold.
The car is starting, but you can tell the battery is getting weaker every try.
Before I buy a new battery, I want to ascertain if it's the battery or the charging circuit.
The car has a dash volt gauge.
The voltage is at 14 before I try to start. The voltmeter goes down to about 9 as it's cranking, stays down there for the first couple seconds after the car starts, then jumps up to 14. The ascent from 9v to 14v is pretty much instantaneous, not a ramp up.
I have a Fluke, what kind of checks can anyone suggest under the hood to tell for sure if it's the battery or charging circuit?
Thanks.
F
feets
Guest
It sounds like it's charging fine.
Weak batteries make themselves known in the cold.
You can clean the battery terminals. that might help a bit if they are dirty/corroded. But, it sounds like a new battery is in order.
thanks
Thank you sir.
I'll get me a battery.
K5MPH
Brownsville Texas,On The Border By The Sea.
Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_2_1 like Mac OS X; en-us) AppleWebKit/533.17.9 (KHTML, like Gecko) Version/5.0.2 Mobile/8C148 Safari/6533.18.5)
Thank you sir.
It sounds like you have one bad cell in the battery you should think about getting a new one soon one bad cell will kill the whole battery.....
new battery
Battery replaced today.
Thanks for the help.
