BCD436HP: Battery Warning Screen
#1
How do I set the warning beep to start before the recording stopped screen comes up? The only beep I get is when the scanner stops receiving and displays the warning screen. I want the beeping to start before that happens so I can intervene before it cuts out. I tried 3400 in voltage but it won't go higher.
PA
#2
You're shortening run time doing that. The voltage setting tells the scanner when the batteries are "dead". A lower setting will let the scanner run longer before it displays the warning and shuts down.
PA
#4
You can't change the battery voltage interval between getting the warning and scanner shutdown. Get higher capacity batteries if you can, or plug the scanner into a USB charger to run it off external power.
