The mystery has been solved for the LCN. Here's what happened when I was originally programming the frequencies...Think you might still have Channel and Talk Group confused. Channel is part of the Site information, while TGs go into the Department section.
If you're still using the menu system for programming, which I think you are, do this,
MENU->MANAGE FAVORITES (Select the Favorites List you are using)REVIEW/EDIT SYSTEM-(Select the System you want to edit)EDIT SITE (Select the Site you want to Edit)->SET FREQUENCIES (either enter a frequency or select one)-> ENTER.
When you press ENTER the next screen will be Input LCN. LCN is the Channel number. For 453.075, the LCN (Channel) is 58. Do that for all of the sites and frequencies for the system and see how that works.
The Fairhope site is no longer active, but both Daphne sites, Foley, and the others are. Last I knew, Daphne PD and FD were in the clear. I think that Fire/EMS dispatch TGs from the 700Mhz system are simulcast on this system. I can check my notes, if you want, to see what I had for active TGs. The information is from late 2016, but except for Foley being encrypted, I don't think much has changed.
I got to the screen to enter the frequency; i.e., Set Frequencies > New Frequency > Input Frequency (MHz) > Enter > Input LCN (Since I didn't know this, I simply hit Enter again which took me back to the entered frequency. And, since I didn't know about RAN, I skipped Set RAN/Area.)
Now, to go about adding the LCN to all those frequencies...
Here's a tip for users to add or edit an LCN. The LCN screen does not appear in a menu selection but rather is a following screen after inputting a frequency. From the Input Frequency screen (add, edit, or do nothing to the frequency), hit Enter and you'll be taken to the LCN screen.
And just like that, within ten minutes, I heard Daphne FD and Robertsdale PD. Thank you very much for your assistance and patience.
Shep
