BC245XLT Tweaking
brimfield
If I send my 245XLT in to Uniden can they tweak it or give a tune-up? It might be my imagination, but it doesn't seem to be as sensitive as it use to be. Its about 5 or 6 years old and has served very well.
DickH
If you monitor Motorola trunked systems with it, it will not be able to track them after the re-banding, now in progress. Depending on where you live, the schedule calls for the process to be completed between Dec., 2007 and June, 2008.
slicerwizard
Toronto, Ontario
Before sending it off, you should check a few things.
Inspect the BNC connectors (scanner and antenna); if the center conductor connection is poor, your reception will suffer.
Remove the battery cover, battery pack and rear case (4 screws); check the connection from the BNC jack to the RF board. Poke it with a (non-metallic) stick to see if it's broken. Reconnect the battery pack, tune to a decent signal and poke it some more. If you get scratchy noises, something's wrong.
While monitoring a known good signal (like a control channel), adjust the tuning cap for best reception. The top of the cap looks like a Phillips screw head and it's at the bottom of one of the round holes (the one furthest from the battery pack) in the big silver RF shield.
