BC250D Handheld / USB Cable ??
Julian1
Fresno, TX
Has anyone had luck finding a USB cable that fits the 250D?
I've got a letter to ScannerMaster inquiring....but if any of you have found one, please advise.
Thanks!!
davidmc36
South East Ontario
There is no USB cable per se. You need the cable that fits the radio and then plug the 9 pin connector into either a comm port or a Serial-USB adapter. Any of the readily available adapters should work fine. I have four different ones and they all work fine with my 296.
torontokris
Toronto Canada
david is correct (as he normally is)
go down to your local radioshack get a serial-->usb adapter
