BC785D with card BCi-25
mikejonessmith
Banned
Ontario
Hey members
I have an old BC785D with APCO 25 card BCi-25 and I am interested/hoping for an up-to-date mem file for Toronto, Ontario Canada for
Police
Ham
GO
TTC
OPP
Anything around the area can help me re-discover the frequencies with an updated mem file?
reply with links or files and comments.
Thank
Mike
torontokris
Toronto Canada
will your software allow you to import a 996 file?
I dont think the 785 will cover the GO transit trunking system as its 9600 baud P25 but im sure you can still listen to it conventionally
mikejonessmith
Banned
Ontario
I'm using BuTel ARC-250 Software....
The BCi2D APCO 25 Digital Card I think it works with P25....
send me files to my email using the username + gmail dot com
.thanks
Raven95150
Nowthen, MN
The 785 will decode APCO-25 digital audio, but it will not track a P-25 trunking system. Looking at the RR database for Toronto, the GO system is P-25 so you wont be able to listen to it. You also wont be able to listen to the subway system since they use a MPT-1327 system, which can't be monitored with any scanner.
http://www.radioreference.com/apps/db/?ctid=4326
mikejonessmith
Banned
Ontario
Torontokris
did you have any file that can be loaded into our scanner help me re-discover the frequencies with an updated mem file?
thanks
captclint
Mountaintop, PA
mikejonessmith said:
Torontokris
did you have any file that can be loaded into our scanner help me re-discover the frequencies with an updated mem file?thanks
ARC250 will not take 996 file. However, you can automatically upload all, some, or one Toronto freq on this site using your ARC250 software. Just become a subscriber: http://www.radioreference.com/apps/subscription/ That is a much better way to update your scanner with what you specifically want. Just make sure you have the latest version of ARC250(V1.20 - Jan. 2008)
torontokris
Toronto Canada
Mike whats ur email?
Its multiple files.. not one single file.. I can zip them up
But as the other memeber said the go transit wont work, nor will TTC (but you can listen to them conventionally (like scanning the scannels with no trunking and no id's)
torontokris
Toronto Canada
just saw ur email ill send it off... try it out worse case it doesnt work as the captian advises it may not work
mikejonessmith
Banned
Ontario
Great job,
Just checking the email now ... thanks ...
wow
Thanks,
