I wrote a review on that Scan Pro software for the 895 years ago - it had potential but the author never really wanted to develop the software so it worked correctly. A shame, really - at the time it was one of many options for working on the 895.
If you really want to expand the number of available channels on the 895, and are using an older computer, get a copy of
Radiomax. I've never been able to make it work on the machine I have now (using XP SP3) but when I had an older 98SE machine it worked like clockwork. Essentially you set up files with up to 300 channels each - and you can have lots of these files linked together. Records, logs and even has a speech interface that actually announces the frequency.
The problem I had was getting the scanning to stop when a frequency is active. I could never get that to work on this machine, for some reason. However you can get a trial and see if it works for you. My review of the software can be found
here . The Radiomax website is still up, surprisingly.
It doesn't trunk, though. If you need trunking,
Scan Control is the way to go. At the time, Winscan was still floating around, and it had the unique - at the time - and controversial ability to let the 895 scan conventional and trunk in one pass. It was thought that this ability stressed the PROMs in the radio to breaking. Unfortunately, this software eventually died off.
None of the software out there will connect to the web service for programming; but Scan Control came close with their copy/paste utility. 73 Mike
