Bc898t Question
scannerman200
North Central Alabama
If i get a BC898T scanner, what all will I need to download the firmware update for it? or will I have to download it? What type of cable will I need and where do I download the update from?
RoninJoliet
ILL
I have a Uniden 898, its a great scanner, the only problem is the manual is "USELESS"...I had a 895 and still have a 245xlt which have almost the same programming. I use it with a outside antenna with "NO" intermod, great audio,PL/DCS instantly, but has no "TEXT". I have not applied the new "firmware update' because im not good with computers....The problem is sometimes when turned on the scanner starts in the "scan" trunking instead of "search trunking"...also , some have had a problem with the PLs disappearing which i never had....Great sensativity, perfect trunking.....You have to check i think pages 47-48 of the Uniden BCT8 manual for CC trunking only as it was left out of whats called a "manual" but the scanner is excellent....PS: Does NOT do Digital
aar9sm
Bc898t
Have you considered the BCT15 does quite a bit more and is closely priced.
aar9sm
