BC898T Tapping ???
k0ke
I have my old analog scanner, what advantage is there to tapping it?
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Putting a discriminator tap into a scanner can net you a lot of neat stuff.
You can decode trunk data channels with a program like Unitrunker, for starters..
You can decode POCSAG or FLEX pager data (the alphanumeric pagers people carry around), though it's of questionable legality to do so..
You can pick up data signals like "weather fax" images, etc., if I recall correctly. My main use of a tapped scanner is for playing around with trunk systems.
You can also do some neat data stuff without a tap.. a few of us here in Calgary are now monitoring ACARS (kind of a messaging format between aircrafts) with only a cable from the earphone output into your computer's sound card.
I have just recently tapped my Icom scanner after meeting up with Jay and HD over coffee and dinner. It really is neat to be able to use Unitrunker with one scanner and listen with the other. You no only have the ability to track whats going on but you have the ability to log new systems that you find in your travels.
