BCD 396xt/346xt power draw
para595
I was wondering if anyone could tell me the power draw of the AC adapter for these I attempted to figure it out and got 25W as the watt draw which does not seem right.
hertzian
Should be more like 2.5 watts.
I place a 396 and a 6V Radio Shack adapter into a P3 International "Kill-A-Watt" meter just for fun.
Without batteries, the most current draw I could obtain with the volume all the way up, was only 1 watt.
With batteries installed and charging, that value went up to 3 watts.
GroundLoop
DC watts at the radio jack, or AC watts at the outlet (before the Uniden AC/DC adapter)?
CoolCat
Just tested my 396XT using an AmWatt appliance load tester...
Battery switch set to alkaline, power off: 2 watts
Battery switch set to alkaline, power on, backlight off: 6 watts
Battery switch set to alkaline, power on, backlight on: 7 watts
Battery switch set to NiMH, power off: 13 watts
Battery switch set to NiMH, power on, backlight off: 15 watts
Battery switch set to NiMH, power on, backlight on: 16 watts
GroundLoop
Seems really really high. I have to wait until I get home to test mine.
GroundLoop
Here's what I measure for AC current with the stock Uniden power adapter:
3.8mA Not connected to radio
38.5mA "Normal Charging"
44 to 48mA Scanning & receiving, backlight on, mid-volume.
I measure 110v AC at this outlet.
So what is that -- 5 Watts?
