I think he's talking more about the signal strength indicator on the display than the actual reception in the original post. It's normal for the signal strength indicator to flash on the screen. This is just a sign that the radio is checking different sites and receiving different control channels on each site with how strong or how many bars are being displayed on the screen. At least that's what I got from the original message.
The other topics that were talked about in replies are also true. And if some of those play a in what was being asked, another thing that will help you receive a specific, single site where you might be addressing an issue of one signal being clear, the next being broken and this resulting in the issue with each other and being synced, and of course distance from the tower will affect how long it takes to get to the signal even if it is microseconds, if you do want to try to get just one site you can also try to use the worst antenna you may have to try and not receive other sites. I had to do this on my BCD436HP. It was really frustrating and of course it doesn't help you if your mobile.
If it is a simulcast issue, then what you really need to receive things correctly and for the most part clearly is the Uniden SDS100 scanner. Another scanner manufacturer named Whistler is also coming out with a new radio soon that supposedly addresses the same issue. That's a whole different topic and issue than just wondering about the flashing signal strength bars on your screen though.
There are really only two radios currently that address the simulcast issue and are available for purchase at a reasonable price. It's the Uniden SDS100 scanner and then the Unication G5 and / or pager which acts more like a real radio and not so much like a scanner. It will lack the functions and features the scanner has but it also does a lot better job on simulcast radio systems and is built more like a real radio and will receive much better then a wideband scanner can.
I don't think the Whistler scanner has been released yet and I've had no experience with their products yet.
I did two short videos, the first with the SDS100 scanner and the second the Unication G5 pager which many of us use as a scanner. In the upper right corner of the screen on the SDS100 scanner you will see the signal strength meter or bars stay solid whenever there's a transmission and then as the radio goes back into scanning you see the bars drop off the screen and come back on as it scans and receives we control channel or data channel. That's it receiving the data Channel and I believe this is what the original post was about. In the second video example, you will see that the signal strength bars do not flash but that's because you only program one site in to monitor at a time for the radio to work properly and like you need it to work. You can program multiple sites but it's going to lock in on the strongest signal and stay on that site only. So if you need it to scan multiple sites like the scanner will do, you're kind of out of luck.
It is normal on the Uniden scanner for the signal strength meter to flash and show the signal strength of the data channel that it is currently receiving as the scanner checks all of the programmed sites or towers on the radio system.
I know this may sound confusing but once you get a understanding of it it is not anything very difficult. It will make perfect sense. I've been up to Fairfax, Virginia but not in about 4 years and it was before they have the radios that are available today 2 help with these simulcast systems which are multiple Towers that are in sync broadcasting the transmission or signal simultaneously. Unfortunately the 325 P2 was not made for simulcast systems even though you can still use it on the systems but you will likely miss some traffic. Just like the previous post was explaining. And you may also have some issues with getting a clean signal and then the reply maybe choppy or not very good. Everybody is moving towards the simulcast scanners in production I believe because it seems that so much of the country has started using this type of trunk radio system.'
Good luck on you're scanning, and if it's just the signal strength meter you were wondering about, I wouldn't worry about that because it's just checking different sites, and that's why it's flashing, as the radio scans multiple sites. That is completely normal for the Uniden scanners.
Example 1 Uniden SDS100 signal strength meter:
https://photos.app.goo.gl/ygUiASCTL7av5Fak6
Example 2 unication G5 pager signal strength meter on one site only:
https://photos.app.goo.gl/4PBGMZV5u8estTnw6
Brian (COMMSCAN)
Sent from my SAMSUNG-SM-G930A using Tapatalk
