I just picked up one of these scanners, programmed one conventional frequency and one P25 frequency. The P25 one is in a P25 system and the conventional one is in a conventional system. How do I select each frequency to listen to? For example, if I’m on scan mode, and it’s picking up the P25 one, how can I make it so the radio will only tune into the conventional channel? I have no idea how to do this, hence why I’m asking. Thank you. I know on my BC125AT I can just press hold and select what channel I want to specifically tune into.
