Its almost the same programming other then the multiple sites which was mentioned
Also the 396T does not do patch takgroups, so either the 396t must be run in search mode or know what takgroups you need
Gymbag is a premium member so he can download into freescan or arc direct from RR
If programming is still a problem one of the homepatrol units would be better HP-1 436HP etc (enter a postal code and it scans)
