Bcd396 UASD help please
Parker,Co
#1
Hi
using the Bcd396 UASD alredy made data base but i need to go back in and change the
System Type. can someone tell me how to go in to change the system Type??
THANKS for any help!!!
Indiana
#2
If you are trying to change a Motorola type for example, double click on the system type site 1 or which ever site number it may be. A drop box will open up and you can select any option available for a Motorola system. If you are trying to change from Edacs to say Motorola, it can't be done. You will have to start a new system.
