BCD396T and BCD996T Updates are Here
South Florida
#41
What Happened
Ok, I have no more ESN # or ESN Checksum anymore on my uniden and I registered a long time ago both of my 996t's. I see this (Get V1 Firmware)...Will this overwrite my old values such as 1.13.01? God I can;t wait till I get off work !!!!...I just want to say thanks Paul for all the help and your techs have been a big help also...
UPMan
Uniden Representative
Arlington, TX
#42
Since we changed the ESN format slightly for the 996, I had the data field wiped before initiating this update. ESN checksums do not exist before the update.
All firmware updates always overwrite the older version.
#45
UPMan said:
Actually, first thing, read the release notes that are linked to on the same page you got the update from. All instructions, troubleshooting, etc are in that document.
Question for all: Should I just have both the update and the update notes "zipped" up together so that they both get d/l?
YES! They should wind up in the same folder, or you have to go searching for the actual update.
North East, MD
#46
Check sum keeps failing. Do I enter everything after the = on the bottom line or just everything up until the , or the whole line including the SUM?
Have tried it every way and it keeps telling me the check sum failed and to re enter a valid check sum?
Cayce, SC
#47
is the checksup only 3 characters? i have only 3 characters and i do have my esn but it will not accept it has valid...i did the update tool and it worked perfect
#48
ok , iv now got version 1.20.13 in the 396 ..... longest 10mins of my life ...thanks to everyone for your help . paul , disregard my emails i guess ...its in ... now i have to drag the 996 out of the car ... here comes another adventure...
K8TEK
Banned
Ohio
#49
DO NOT enter the 32826, enter everything after that for the ESN.
#54
Sjinndoawi said:
Thanks Viper....Now if uniden could only speed up the time so I could GETTTTTTTTTT OFFFFFFFF WORKRKKKKKKK...it's only 2:30
LOL, they could however speed up the website..... it's slow on a normal day, but god is it ever sloooooooow today! I think thats part of the issue with folks getting all the errors.
UPMan
Arlington, TX
#56
Added ESN, QSC, CSC, and PWR to the PC protocol
I'm getting on a plane for Asia first thing Saturday, so probably won't be able to get the updated protocol document out until I return (after the 21st). Below is a quick description of each.
ESN: Report out the scanner's ESN and Checksum
QSC: Set current frequency and get reception status
Controller → Radio ① QSC,[FRQ],[STP],[MOD],[ATT],[DLY],[SKP],[CODE_SRCH],[BSC],[REP][\r]
Radio → Controller 1. QSC,[RSSI],[FRQ],[SQL][\r] or QSC,NG[\r]​
CSC: Go to custom search and get reception status
Controller → Radio
① CSC,ON[\r]
② CSC,OFF[\r]
Radio → Controller
① CSC,[RSSI],[FRQ],[SQL][\r]
CSC,[RSSI],[FRQ],[SQL][\r]​
PWR: Get RSSI level (0-1023)
Controller → Radio
① PWR[\r]
Radio → Controller
① PWR,[RSSI],[FRQ][\r]​
As to using the remote head to turn on the scanner...no. When the scanner is off, there is no way for it to receive any serial command.
#57
Upman, actually the Updater, Update and install instructions should all be together, it may make things quicker in the long run, and the Updater and Update shoul be in the same folder anyway.
