This firmware applies the following changes from V3.00.00:
- Restored autotracking of Motorola 800 Standard systems in Control Channel Search mode.
- P25 test mode setting defaults to 3 for best decoding performance.
- Communications will no longer be locked up between the scanner and the remote head if AGC settings are accessed.
- Fixed the CSC command to no longer return to the menu after CSC,OFF is received.
- Fixed the CSC command to properly report out all RSSI levels for all frequencies.
- Scanner no longer resumes scanning after pressing "." then the first digit of a SQK
- If backlight is set to infinite, it will no longer turn off after receiving a Close Call hit. (BCD396T Only)
