bcd396t programming help
kc9msa
I am new to the world of scanners....I am a ham, and had no problem at all programming any of my radios or my HT using computer software. This thing has me stumped. Local law enforcement in my area is on APCO 25. No where in any of the programming software does it have a slot for "control frequency" or anyhting of that nature. I am stupmped! Can someone please help me!!!!
regression
Germantown, TN
Which programming software are you use? Assuming you are using the UASD software from Uniden, on the main screen, click the "Data Base" tab, then "New" under "System Data Base". Give it a name and select the type and click OK. On the window that pops up, click the "TRUNK Option" button at the bottom. You enter the system frequencies there.
kc9msa
Right...
Well, my question is, with our local system, there is one primary control station frequency, then a couple of alternate control channels, then the regular frequencies...how does the software know which frequency is the primary control frequency?
captclint
Mountaintop, PA
You may find this helpful. Most recommend CC only. http://wiki.radioreference.com/index.php/Control_Channel_Only
n2mdk
Ames, IA
Since only one control channel frequency will be active at any one time the radio scans and locks on to the first one it finds is active. If the system rotates control channels the radio will simply move on to the next active one.
