BCD396T Scanner
jerk
jerkville
leawoodcops said:
Will a BCD396T Scanner work in the 700 Mhz. trunking?
Yes it does and it also receives conventional analog and digital traffic as well.
jerk
jerkville
leawoodcops said:
so it will trunk track
Downtown Houston 774.08125* 774.29375 774.79375 775.29375 775.79375*
http://www.radioreference.com/apps/db/?sid=4563
Yes, it should with no problems, you may have to put in each site as separate system, but they could all have the same Quick Key to turn on and off for scanning.
The 996 can do multiple sites with one system, the 396 can't, each site has to be a separate system.
