BCD396XT and EarthMate GPS question
Moosemedic
Denver
Greetings,
I'm trying to connect an older yellow EarthMate GPS receiver to my new 396XT
I've got the gender changer to adapt the serial cable on the GPS to the Serial to proprietary Uniden cable. With fresh batteries in the GPS I connected this to the side of the scanner, but nothing happened.
The only videos I have been able to find are for the HomePatrol and indicate it should automatically recognize the GPS being attached. I've looked through the massive manual and can not find a way to configure this to recognize that there is a GPS attached.
Questions to the Forum;
Has anyone used this type of GPS with these scanners?
Is the 396xt capable of GPS use?
(I have configured this setting - range using FreeScan)
Thoughts about how to make this work?
phask
KZZV - SE Ohio
Need to make sure the baud rate - etc. are the same. Not sure where in the menu it is because I have not had mine connected in years.
dkf435
Sweet Home/Foster OR
Moosemedic
Denver
Thanks everyone... I have the older yellow EarthMate...
Doesn't put out NMEA, so no joy there.
So I fired up my Geko 301 which is saying it's sending NMEA at 4800 baud. The scanner Serial port is set to 4800 baud (I down graded from the 11520 it was set for programming with FreeScan) as well and still shows no GPS input data.
Any idea what's wrong?
UPMan
In Memoriam
Arlington, TX
Depending on the cables you are using, you might need a null-modem adapter in the setup.
SB-Wi
Eastern Dane Co
The scanner needs NMEA-0183 ver. 3.01 compliant, including GGA and RMC sentences.
The Geko 301 owner's manual shows NMEA-0183 ver. 3.0
frazpo
SW Mo
UPman
UPman,
Why is it when entering a POI manually in the GPS settings the format is as follows,,
00.000000N
000.000000W
My west coordinates only have 2 digits with a preceding (-) sign. How do I enter it in this format?
UPMan
In Memoriam
Arlington, TX
The "-" sign means West. If you are not so far west as to need 3 digits before the decimal point, use only two digits.
