BCD396XT Help
terryyvr
Vancouver BC
Could someone be so kind & help me out on how to unlock a locked out Talk Group that is on the EDACS System.
Many Thanks.
kma371
Go to the talkgroup you want unlocked and hit the lockout button again.
Sent from my iPhone 4 using Tapatalk
Keith_W7KEW
California
Many Thanks.
Depress the Scroll Knob, then release it, then turn it to the EDACS System you want to edit.
Wait for the F icon on LCD to drop after 3 seconds.
Turn the scroll knob to the Talkgroup you want to unlock then press the L/O key
or
Press Menu > Program System > Turn scroll to EDACS System > Edit Group > Select Group with TGID to Unlock > Edit Channel > Select Talk Group ID > Set Lockout > Unlocked
N8IAA
Fortunately, GA
or
OR, you could press Hold while in the system and scroll to the TG, then press Func, then Lockout. Less key presses.
Larry
