BCD396XT Programming Question
papadoc
NW Oklahoma City
Somehow, my Cleveland County OKWIN site for Norman is scanning as NFM, when all the other channels for OKWN show the primary control channel under the ID Scan line that scrolls across the screen. How do I change the site from NFM to the primary control channel? I've looked and can't find how to edit that option. And I hope I've explained it correctly.
dshafer1
San Jose, CA
Hold on any channel and press Func then 6(disp). Press Hold to resume.
papadoc
NW Oklahoma City
That allowed me to change from NFM to nothing on the screen, which also changed all the other channels from showing the primary control channel to nothing. Not exactly what I wanted to do. But thanks anyway.
W8RMH
Feed Provider Since 2012
Grove City, Ohio (A Bearcat not a Buckeye)
It will display NFM if it does not have good reception of that control channel. Try moving the radio or antenna to improve reception, then the frequency should display. There is no setting to control this.
papadoc
NW Oklahoma City
That's probably the answer, since I'm north of the Norman Site range, and I'm not using a base antenna. Thanks for the info. Appreciate it.
