BCD396XT stoped decoding P25.
wizz5500
Boonton, NJ, USA.
After updating the firmware to version 1.08.14 sum162 ver1 The APCO P-25 now fails to function on all systems. Please advise! Any help would be greatly appreciated.
DaveIN
Founders Curmudgen
West Michigan
So your saying the P25 systems you were able to decode before are not being decoded after the firmware update? You could try a reset of the radio (2,9, HOLD, power on) and then reload your systems using FreeSCAN. If that still does not work you could try updating the firmware again. Make sure you back up you memory first with FreeSCAN or you'll loose the memory contents.
