BCD325P2: BCD396XT to BCD325P2 Cloning
#1
I have a BCD396XT and was wondering if I could clone by current set up into the BCD325P2 scanner? Not sure if this could be done or not or if the BCD325P2 even has a Clone feature.
South Arkansas
#2
I don't think you can clone them. But you probably can use software to do it. If you have Butelsoftware or maybe Uniden's software. They should be able to read the files
phask
KZZV - SE Ohio
#3
Since Uniden has no software supporting the 325 that won't work :) I use Freescan - works for 396 and 325.
#4
I do have everything from the 396XT loaded into Freescan. Should I be able to download that right into the BCD325?
