BCD436HP and "unknown TGID"
jdcaples
Seattle, WA
After a 20 year hiatus, I'm revisiting the scanner hobby. I live and scan within the city limits of Seattle.
I have a BCD436HP.
For the first few days, I just listened to everything picked up by zip code.
Today I decided to set a goal of configuring the scanner to only pick up Seattle Police Department radio chatter.
I installed and updated both Sentinel and the scanner.
I then created a profile I call "SPD."
I removed everything from the favorites list except Seattle Police, Capitol Hill (Seattle backup) and Seattle Simulcast.
I wrote this configuration to the scanner.
This configuration picks up all SPD talk groups.
However, it also locks onto - what the scanner reports as - "unknown talk groups;" Bothell Police Dispatch, for example.
I suspect somewhere along the way, I made a mistake.
Might someone help me figure out how to use Sentinel to configure my scanner to only pick up SPD traffic?
Thanks in advance!
-Jon
ChrisP
Portland, OR
You need to make sure the system is set to "ID Search" = OFF. If ID Search is on, it will stop on any active trunked talk group that is not avoided (locked out). ID Search off insures it will only stop on the groups you have active in your favorites list.
- Chris
marksmith
Anne Arundel County, MD
Yep.
Go into the effected system by editing favorites list.
Select the system, and then turn ID search off (or use ID Scan)
It will only receive those talk groups not locked out and included in your scan list
Otherwise it receives all active talkgroups not locked out, including ones not in your favorites list.
536/436/HP1/HP2/996XT/996P2/396XT/325P2/PSR800
devicelab
Whacker Extraordinaire
Nowhere in WA
Make sure you are using the custom band plan for rebanding. It seems like RR screws that up every other update. If you create the system by yourself, then you'll need to add the custom band plan.
