BCD436HP battery swap - no output
mspIggy
#1
this has happened for the 3rd time in 8 days
swapped the batteries - output ceases
the unit is still scanning my selected favorites list - no output
previous 2 times i reformatted card - reloaded lists...
there must be something else going on -
i know we should not have to reload program with each change of batteries...
thoughts?
thank you
Phil
buddrousa
NW Tenn
#3
Turn off the scanner before removing the batteries. Wait for the scanner to turn off. Removing the batteries while the scanner is turned on will cause the SD Card to have problems.
