BCD436HP Question
NJEMT12982
NJ
Everyday when I turn on my scanner, the clock settings have been lost and I have to input the date and time. I have updated the firmware, says it's up to date. Any idea why I am constantly having to re do this?
sparklehorse
Portland, Oregon
You'll get this message If the clock battery in the 436 is drained. The battery only charges when the radio is turned on, so if you've not used your radio for a while you will get this error. I think I've gotten this message after just a couple weeks of non-use. When your radio is new you have to let it run continuously for 50 hours to fully charge that battery. If you did that, and you've been using your radio daily ever since, then you likely have a bad RTC battery and need the repair program that Buddrousa linked to.
