Good evening everyone. First of all, I am new to posting here, as well as very new to this scanner since I recently just got it, I had a Whistler 1040 before so this is definitely a learning curve. I will start with what I got set up so far, I got the scanner, updated it and everything and updated the database. I set up some favorites off of that database and there is a P25 Phase II local site that supports PD, FD, etc. Well when I hold on a specific talkgroup within that site, I will get signal bars and "NFM" appears along with "DAT" but the strange thing is, the signal bars fluctuate along with "DAT" fluctuating then it all completely drops out. I will hear transmissions when there's signal and "DAT" is displayed. When the signal drops out, I will switch the modulation between auto, NFM and FM and when I get back to auto, the signal picks back up and I can listen to it again then the same cycle repeats with the signal going out after a while. Does anyone know what is going on and why the signal does this but works when I switch between the modulation types? Hopefully this makes sense to someone, I am very new to this type of scanner and learning as I go and would greatly appreciate any advice or tips anyone can provide. I do apologize to anyone if I am not explaining things properly since I am new to this. Thanks again to anyone that can help.
