The internal charge system in the scanner doesn't work very well. You'll need an external charger that charge each battery separate and not connected in series. It needs to have a temperature sensor as when the battery are fully charge it will instead convert all charge current into heat, and heat destroyes batteries. I have one charger where each battery rests on a temp sensor.
/Ubbe
