BCD536HP Audio Record Playback Metadata
an39511
Cleveland, Ohio
#1
I have been extensively using the record function to assign unit IDs (UID) but about 20% of the time it is not showing the UID of the transmitting station. In addition, another 10% of the time the UID is showing up on the on the transmission following audio sample. Needless to say this is not very useful in trying to determine UID assignments.
My UID list has about 110 entries so far and this problem only appears to be in the recording playback and not showing up on the on the live display during normal scanning or while it is actually in record mode.
Anyone else experience this?
