I'll keep my fingers crossed for you. I am starting with the 436 but do want to pick up a 536 in the next couple of months or so and having the issue solved would definitely be nice.
Ive been playing with this for a while, and it appears that the 436 and 536 have the same issue. If either is on HOLD on any channel, and the priority channel transmits, they both jump right to it. Be if either one are scanning, and stopped on an active transmission when the priority channel transmits, they DONT switch to the priority channel, they just keep playing the channel they were stopped on. Im trying to catch them on HOLD on a channel while its transmitting and see if they interrupt the transmission to jump to the priority channel.
Same for me on the BCD536HP, BCD436HP and my BCD396XT if you have priority set for a TG on a P25 digital system and your holding on a TG they will all switch right away to the priority TG but when scanning they will not. On my PSR-800 priority works fine when scanning.
Mike
I guess it is working correctly then, since it says it only checks "in between transmissions", which if you were scanning, it would stop on anyway, so I guess its fairly useless to set a priority channel at all. I was thinking it would actually check during the transmissions.
Most likely the system (on the radio side, not your scanner) is not set up to have that fire channel as a priority channel. If they system does not have it flagged as priority on their side, then the data indicating the channel is active will never appear in the priority channel data on the voice channel, and the scanner will have no way to know that it is active.
I'm not sure what you're saying...... I believe he set the channel/TGID as a priority.
How do I go back 1 firmware revision? This new firmware revision has made my reception of my local P25 Phase II system, Camden County Public Safety Trunking System, Camden County, New Jersey - Scanner Frequencies, poor to just OK at best. Before this revision I had made the NFM to FM change, I remove any frequency that was not transmitted by the closest site - Lindenwold, set the ATT on for the system and my P25 Phase II was almost 99%.
There is no way to go back. You are among many complaining about the latest firmware.
Sure there is. It works just like the original Home Patrol.
All you need is to have saved a copy of the previous FW update you did and place that file in the firmware folder of the scanners SD card while the card is in the scanner.
As soon as you unplug the USB cable, it will apply whatever FW version it sees in that folder even if it is an older version.
I did not keep 1.02.07 which I think was the one just before 1.03.03 so maybe someone else will have a copy they can put somewhere.
You can save a copy of the firmware file by checking for FW updates with Sentinel and then when it finds and downloads a new version, it will tell you to unplug the USB cable. Don't do that step yet and instead, use explorer and go into the SD cards drive letter and the firmware folder and save a copy of the .BIN file which will have the radios model and firmware version as part of the name. Once you have that saved, then unplug the USB and the new FW will be installed but you will have a copy as well. Then when the next FW is released and found to break something, you can easily reinstall the copy you saved.
Trunked systems have a feature called Priority Monitor. Certain talkgroups can be designated as Priority in the system and when they go active they're flagged as such on the control channel data stream and the low-speed data which accompanies an active voice talkgroup. The Uniden scanner is watching for those priority flags in the data; if a talkgroup is not designated as Priority Monitor in the system, there won't be a Priority marker in the data, and the scanner won't see it as active while another talkgroup is being monitored.
