BCD536HP -NAC settings?
werinshades
Chicago , IL
So the link you provided says that the Uniden Bearcat BCD536HP has the NAC feature. But @wearinshades says it doesn't.
Go into your Sentinel, click the Site tab, and let me know where it asks you "Use NAC Code yes/no" under the 436 profile. That's the setting he's asking about.
werinshades
Chicago , IL
Oh you meant just trunked systems. I didn't think trunked systems needed an NAC since the computer controls it all.
In the event two trunking systems are in range of each other, and use the same frequency or frequencies but different NAC's, that's where the setting is beneficial.
JethrowJohnson
I love P25
Marietta OH
I see what you're saying now. I thought you were just talking about conventional P25 frequencies.
Ubbe
Stockholm, Sweden
And then it would be just as beneficial to the 536, but Uniden haven't added that 5 lines of code to the x36 series, making Sentinel and the scanners programming identical to the SDS series for trunked NAC codes.
The SDS series needs all the help it can get to sort out RF problems that the x36 series do not have. The SDS's poor selectivity and receiving of mirror frequencies made it necessary to add the filter settings and the additional NAC for trunked systems, that could just as easily have been added to 436/536 but haven't been done as it isn't needed there.
/Ubbe
werinshades
Chicago , IL
/Ubbe
Oh boy...here you go again... :LOL: I don't know the reasons, but if two systems are using identical frequencies and are both in range, the SDS series will have the upper hand as the x36hp series doesn't have the capabilities and will probably have a problem with decoding the system. Then again, the x36hp blows chunks when it comes to simulcast unless you have the perfect location/perfect beam antenna/pointing at the perfect point of the antenna/ when the wind isn't blowing from the wrong direction, and....and.....you bend the paper clip just a tad more. So there...:ROFLMAO:. Plus...you certainly have alot of issues with a scanner you still don't own so pipe down over there.
