IF frequencies are here…
I have spent a week trying to locate information on I.F. specifications for the 536 HP. I have searched countless posts about the subject. I usually find the same question I have, but then no specific answer from anyone, and the subject drifts off in the threads. I have tried to work with...
forums.radioreference.com
I suspect the reference oscillator is a soft pot and takes a test mode to access.
I hope not, unless the test mode is published. Anyway thanks for the link to the data below. I will sniff it out and see how it measures. I did perform an offset acceptance bandwidth test in FM mode and the radio seemed "on freq" - indirectly. But for digital I want it to be dead on. Thanks
From UPMAN (SK)
1st Heterodyne:
25.000-319.995 MHz : Upper Heterodyne 380.75 MHz
320.000-511-995 MHz : Upper Heterodyne 265.55 MHz
758.000-805.995 MHz: Lower Heterodyne 265.55 MHz
806.000-1300.000 MHz: Lower Heterodyne 380.75 MHz
2nd Heterodyne:
25.000-319.995 MHz: Lower Heterodyne 10.800 MHz
320.000-805.995 MHz: Upper Heterodyne 10.800 MHz
806.000-1300.000 MHz: Lower Heterodyne 10.800 MHz
3rd Heterodyne:
All Bands: Lower Heterodyne 450 kHz
Uniden "Big Daddy" Product Ninja
