I have the BCD996P2 and it does not use a SD card, it uses a USB cord. The sentinal software does not see the
USB . I've downloaded the drivers and latest software from Uniden website to my Windows 11 computer
abyone have an idea of wht I can try.
Your software choices include:
ProScan
ARCXT
And FreeScan
As the name implies, you can download and use FreeScan at no charge or fee. However, this software was abandoned by the author and no updates for many years past. Also, if, at some point, you add the upgrades for DMR and NXDN, FreeScan does not correctly handle DMR systems, and does not support NXDN at all.
ARC-XT can program this model. The “basic” version is about $40. This handles programming and a couple other things. But if you want “Virtual Control” (controlling the scanner with your PC, you have to buy the “Pro” version, about $70. ARC-XT supports Uniden XT scanners (396xt and 996xt, your 996P2, as well as the 325P3 and BCT15X.
My choice would be ProScan. The cost is $50, and that has programming, logging and recording capabilities, as well as virtual control. It supports multiple Uniden scanner models: the same ones ARCXT does, plus Uniden’s x36HP and SDS series scanners, along with a number of older models which have been discontinued quite a few years ago.
All three of these software programs support downloading systems from the Radio Reference database if you become a premium subscriber. ARC-XT and ProScan correctly handle both DMR & NXDN systems; both of these also provide free updates if something new has been added, or a problem fixed in the software after you have purchased and installed. As already noted, no updates to FreeScan in quite a few years, and no future ones will be released.
