BCD996 programming
Chappell Hill TX
#1
I am using BCTool to program my scanner, with CSV files from RR.
On the Arkansas Awin system, I appear to be successful in programming, but the
scanner decodes nothing.
While looking at it, it shows the system to be 800 mhz trunking, but I do not find
a tab for 800 Mhz trunking P25. Should I need to do that? as this system is P25,
should I be using something else?
Airdorn
#2
When setting up the new system, choose Motorola type 2/P25.. then when setting up the new site for that system, choose P25.
See if that works.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
#3
In addition to the comment below, you don't want to be importing the csv files from RR. You are a premium subscriber; so you should be able to log in with your login/password (same as the one you use here), and connect directly to the database, then download what you need.
73 Mike
Chappell Hill TX
#4
Thanks... I had NOT been able to do much with the CSV's, I was downloading directly.
I am headed through KY to Nashville tonite, I will try some of those and see what happens.
