BCD996 programming
iamhere300
Chappell Hill TX
I am using BCTool to program my scanner, with CSV files from RR.
On the Arkansas Awin system, I appear to be successful in programming, but the
scanner decodes nothing.
While looking at it, it shows the system to be 800 mhz trunking, but I do not find
a tab for 800 Mhz trunking P25. Should I need to do that? as this system is P25,
should I be using something else?
Airdorn
Cordova, TN
When setting up the new system, choose Motorola type 2/P25.. then when setting up the new site for that system, choose P25.
See if that works.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
In addition to the comment below, you don't want to be importing the csv files from RR. You are a premium subscriber; so you should be able to log in with your login/password (same as the one you use here), and connect directly to the database, then download what you need.
73 Mike
iamhere300
Chappell Hill TX
Thanks... I had NOT been able to do much with the CSV's, I was downloading directly.
I am headed through KY to Nashville tonite, I will try some of those and see what happens.
