Setting Channel Alert MECL
[MENU] -> Program System ->
-> Select a system ->
-> Edit Group ->
-> Select a channel group ->
-> Edit Channel ->
-> Select the channel ->
-> Set Alert ->
Off — the scanner does not alert you when the channel becomes active.
Alert 1 - 9 — the scanner sounds an alert beep to notify you that the channel
has become active. You can choose any of 9 different beep types. Once you
choose an alert tone, then:
-> Set Level ->
Auto — the scanner automatically sets the channel alert beep to match the
master volume level.
Level 1 - 15 — the scanner adjusts the volume of the beep to the level you
select.
