BCD325P2/BCD996P2: BCD996P2 talk group locking/unlocking
frankie811
Providence, RI
I have a BCD996P2 & every once in a while talk groups that I've locked out permanently become unlocked on their own. Is this a design flaw or is this an intentional feature?
Randyk4661
Garden Grove, CA
If you press lockout once then it is a temporary lockout and will be unlocked next time you turn on the scanner.
to permanently lockout, press lockout twice quickly.
Randyk4661
Garden Grove, CA
Hmm, are you reading and writing to and from the scanner with software? if so check to see that the software shows the lockouts after reading from the scanner.
I have a 996P2 and never had this problem.
frankie811
Providence, RI
It's really not a big problem. I can live with it. I love my 996P2. :)
Double check to see whether you have duplicates programmed.
Also, make sure the scanner is in ID SCAN mode - NOT ID SEARCH mode.
I don't know how to switch between the two. :)
sonm10
Central MN Monitor
Sauk Centre, Minnesota
Are you programming using Proscan by chance? Whenever I write to mine, I lose lockouts. Even when programmed as lockout!
CT
Also re-read post #2 which explains temporary lockout vs Permanent lockout.
Press Lockout ONCE and the lockout is only good until you power off the scanner.
ProScan
Software Provider
Ontario, Calif.
Is that TGID lockout? That shouldn't happen on ver. 19.2 and later. There was a problem with the Settings - Lockout TGID grid. Uploading the settings lockouts would conflict with the systems upload so the Settings - TGID lockout grid was made read only.
