BCD325P2/BCD996P2: BCD996P2
N0BDW
Livingston Co., NY
bwalv,
Are you using the supplied USB cable? It'll only work with the special Uniden USB cable. A generic cable will not work.
ProScan
Software Provider
Ontario, Calif.
my computer will not find my BCD996P2 scanner using a USB connection what can I do.
bwalv
Try power cycling the scanner. If it still doesn't work, go to the Win Device Manager and see if the port shows as working.
phask
KZZV - SE Ohio
That is not true at all - all it IS is a generic cable.
Don't confuse it with the USB1.
bwalv,
bwalv
Sheboygan Falls WI.
I downloaded the driver and the computer says it is installed. I am using ARC-XT basic software i got from scannermaster. When i click on scanner then configuration editor I can change things in the computer and send to scanner but when I try to send a system to the scanner it pops up that no scanner is connected and I am using the supplied cable
Thanks for any suggestions.
bwalv
RRR
OFFLINE
USA
Last day of 2016, Mr. Gommert..... ;-)
bwalv
Sheboygan Falls WI.
Thank you updating the software finally worked, I tried clicking the update button but that did nothing. Now having trouble i added a p25 system and not getting any sound at all. I am a new user so I guess I keep trying.
bwalv
bwalv
Sheboygan Falls WI.
Finally got my scanner programmed and it is receiving but the audio is very hard to understand. It is a BCD996P2 scanner and a digital P25 system for Sheboygan county in Wisconsin.
bwalv
bwalv
Sheboygan Falls WI.
I think my problem is I need a better antenna than what came with my BCD996P2 it sounds better and gets more reception when i put it right by a window. Can anyone recommend a good antenna that would help me, I will need an indoor antenna, I could possibly get it up in the attic over the garage if absolutely needed. Thank you for any recommendations.
bwalv
