vicmiller1
BCD996XT and BCD396XT TalkGroup Wildcards ?
Looking for the simplest setup for both Motorola Analog Trunk (NJ State Police use this) and
P25 Digital Trunk (NJ Bergen County-Wide system uses this) with 996XT, 396XT types ...
I've just read the manual ... All OK ... New System (set for P25, etc), New Site (one or more sites / towers)
Then Enter Frequencies (with control channels of course), but then a little bit of a twist ...
The manual says at this point you can "Search" the system (P25 system) which I interpret as opening up / following any and all TalkGroups / TalkGroup ID's ... (which is sort of the simplest thing ... to me it's like a TGID "Wildcard") ... but if I have other stuff programmed that I want to Scan (not Search) ... then the manual says (and I can see that , it makes sense sort of) must have a ChannelGroup and then set a Channel (which to me is the same as a TalkGroup ID) within a ChannelGroup ... so here you have to know the TGID ... Is there a wildcard (to take / open up on) any and all TGID's ... ?
I want to Scan but with TGID wildcard ... Or if Search (instead of Scan) effectively creates the wildcard function ... Can you Search a particular system like a P25 system and still "Scan" other programmed items like repeaters / conventionally programmed frequencies ?
I find the RadioShack PRO-106 and similar PRO-197 to be more straightforward ...
You make a New System (P25 Auto type) ... make a site / bank ... enter the tower frequencies and for TalkGroup ID (TGID) they have a "Wildcard" choice ... so if you don't know the exact ID it will open on any and all TGID's ... which effectively means it just dynamically follows the real-time tuning commands and opens the audio ... I'm looking for the equivalent of this approach for the 996XT, 396XT (latest / current digital base and hand-held radio types)
Many Thanks,
Victor L. Miller
vicmiller1@aol.com
Many Thanks,
Victor L. Miller
vicmiller1@aol.com
