BCD996XT: Bcd996xt Baud Rate question
nick223
Ottawa Illinois
#1
Im programming a Uniden bcd996xt with Proscan and the scanner will only communicate with a baud rate of 9600. Normally all my other uniden scanners including other 996xt's use a baud rate of 115200. Is there an issue with the scanner or can you change the baud rate on the scanner? Not really sure why its using the 9600 rate.
