I use the Garmin OEM 18X WITH DB-9 connector with my bcd 996t.I'm looking for a good GPS receiver for my BCD996XT and I can't seem to find a place to purchase it.
Any help here?
What's the advantage with this kind of setup?
You jack the GPS receiver in and then what?
you can order it from gpscity.com are do your on web search for other suppliers.
Mike
Where did you get the splitter I need to split for Scanner and Computer softwear..
Thanks Ron
Thanks, that will be a big help... Ron
Compatible GPS receivers
Any GPS receiver meeting the following requirements:
* Female, 9-pin serial connector
* NMEA-0183 ver.3.01 compliant, including GGA and RMC sentences.
[edit] Examples
* Scannerforce GPS
* Garmin GPS 18 Note: Superceded by GPS 18x PC
* Delorme Tripmate (with modification for autostart)
* GARMIN eTreX Note: Now discontinued
* GARMIN eTreX Legend Note: Now discontinued
* GARMIN eMap Note: Now discontinued
* GARMIN Rino110
* GARMIN GPS 18 PC Note: Superceded by GPS 18x PC
* GARMIN GPS 18x PC
* GARMIN 12XL Note: Now discontinued
* GARMIN GPSmap 60CS(x) (needs Garmin 010-10141-00 or equivalent cable) Note :CS is discontinued CSx is still available.
* GARMIN GPS2 Plus Note: Now discontinued
* Lowrance iFinder GO2
* MAGELLAN Meridian Marine Note: Now discontinued
* MAGELLAN Triton 2000 with 930-0017-001 Serial Cable (or equivalent serial cable).
* Uniden Mystic
* GPS1 Module Kit sold via Scannersoft website Note: No longer available.
* HOLUX Mouse GR-213 (when ordered with a serial cable)
