BCD99T & BCT15 WFM Modes
pboy
KHKY
What is the difference between WFM and WFM (Broadcast) modulation modes on the BCD996T & BCT15?
Obviously WFM (Broadcast) is for FM radio and TV audio.
What would WFM be used on then?
No specifics on modulation parameters is published anywhere.
Uniden has never had two different options before.
pboy
KHKY
Thanks for the clarification.
So earlier Uniden models did not correctly handle FM broadcast mode?
