BCDx36HP Recording Meta Tags
DaveIN
Founders Curmudgen
West Michigan
Hi Steve, yes they do. When you do a replay of the recordings you see it on the display.
Dewey
Not exactly... the formatting appears different. I found this thread searching hoping that someone already had what was stored with each tag. Oh well.
EDIT: While looking at the makeup of the files, it does look like the same tags are used, however, the IPRD, IKEY, ICRD, ISRC, and ICOP tags end with x10h instead of the "normal" x40h, which is throwing of the tag reading in apps like HP WavePlayer.
